Activity › Forums › Adobe After Effects › Shrotcut key to scale composition window to fit?
  • Shrotcut key to scale composition window to fit?
    Posted by Jaso Allen on June 16, 2006 at 5:02 am
    Hi there everyone,
    I’ve searched the manual top to bottom but can’t seem to find if there’s a shortcut key to fit the composition window. I’m always having to do it by mouse and it annoys the hell out of me.
    Does anyone know if there is one?
    Thanks guys.
    Jason Allen
    Jaso Allen replied 20 years, 3 months ago 3 Members · 4 Replies
  • Tim Kurkoski
    June 16, 2006 at 3:56 pm
    If you’re using AE7, the / (forward slash) key is your friend. By itself it zooms to 100%. Add shift and it zooms to fit the size of the comp window. Use Alt instead and it zooms to fit or 100%, whichever is larger.
    I found these while rooting about in the AE shortcuts file. Always a fun time.
    C:\Documents and Settings\\Application Data\Adobe\After Effects\7.0\Adobe After Effects 7.0 Shortcuts.txt
    If you’re on an older version of AE, try using the zoom shortcuts (comma, period, and forward slash) in combination with the Comp window sizing shortcuts (CTRL with – and +). Between the two sets you should get what you want.
  • Todd Gillespie
    June 16, 2006 at 5:28 pm
    Great info Tim!
    Thanks for sharing in your findings.
    Todd at UCSB
    Television Production
  • Tim Kurkoski
    June 16, 2006 at 5:53 pm
    Hmmmm… the Cow’s forum system seemed to clip out small part of my post.
    The correct file path is:
    C:\Documents and Settings\[username]\Application Data\Adobe\After Effects\7.0\Adobe After Effects 7.0
  • Jaso Allen
    June 25, 2006 at 12:59 pm
    Thanks heaps for that tim. Couldn’t find it in the documentation anywhere.
    Jase
