Activity › Forums › VEGAS Pro › Shrink 16:9 to 4:3 in Sony Movie Studio 10
  • Shrink 16:9 to 4:3 in Sony Movie Studio 10
    Posted by Val Kotelnikov on January 7, 2016 at 9:27 pm
    I have a .MPG file created by conversion of analog VHS 4:3 (from 90th). However it was converted to 16:9 – as a result it’s stretched horizontally. I want to change the aspect ratio back to 4:3 before start working on it. Tried to render as 4:3 – no good.
    Please, help!
    Val
    John Rofrano replied 10 years, 8 months ago 3 Members · 14 Replies
  • 14 Replies
  • John Rofrano
    January 7, 2016 at 11:00 pm
    [Val Kotelnikov] “I want to change the aspect ratio back to 4:3 before start working on it.”
    Drop it into a 4:3 project, then open Track Motion, disable Lock Aspect Ratio, and drag any corner to fill the 4:3 screen (which will stretch it back).
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Wayne Waag
    January 7, 2016 at 11:14 pm
    First, set your project properties to 4:3, e.g. NTSC DV (720 x 480). When you import your 16:9 file, there should be black bars on top and bottom. To fill the black bars and stretch your image back to 4:3, open the Pan/Crop box. Under Source, Change Maintain aspect ratio to “No” and Stretch to fill frame to “yes”. The black bars should disappear and your frame should be filled at the correct aspect ratio. In the event I misunderstood your problem, a screen shot would be useful.
    wwaag
  • John Rofrano
    January 7, 2016 at 11:46 pm
    Good point. Wayne’s approach will fix it at the event level so you would do this to each event. My way fixes it at the track level so any event placed on that track will be stretched. I kinda like Wayne’s way better if you don’t have a lot of events.
    ~jr
  • Wayne Waag
    January 8, 2016 at 1:21 am
    Even if you do, just copy the first event after making the correction, select the remaining events and PEA (Paste Event Attributes). This way, you can have other events on that track that are not 16:9 such as stills. That’s the nice thing about Vegas–there’s usually more than one way to get the job done.
    wwaag
  • Val Kotelnikov
    January 8, 2016 at 12:21 pm
    Oh … thank you very much. I used Wayne’s approach on one file and John’s on the other. To-morrow I’ll be back with the results!
  • John Rofrano
    January 8, 2016 at 1:38 pm
    [Wayne Waag] “That’s the nice thing about Vegas–there’s usually more than one way to get the job done.”
    Indeed, there usually always is. 😀
    ~jr
  • Val Kotelnikov
    January 8, 2016 at 2:40 pm
    Wayne’s way worked perfectly well, the other one is still under way.
  • Wayne Waag
    January 8, 2016 at 4:39 pm
    Glad it’s working for you and that you’ve now learned the two ways of doing it. Using these two methods in concert allows you to do other things, e.g. crop the image first in the pan/crop window and then move it around using track motion to create a picture-in-picture effect. Lots of possibilities.
    wwaag
  • Val Kotelnikov
    January 8, 2016 at 6:11 pm
    Thank you. Be ready for more questions 😉
    “A fool can ask more questions than 100 wise men can answer” (Chinese proverb)
  • John Rofrano
    January 8, 2016 at 7:38 pm
    [Val Kotelnikov] “”A fool can ask more questions than 100 wise men can answer” (Chinese proverb)”
    Better to be thought a fool, then to open your mouth and remove all doubt! 😉
    Just kidding… we love questions… what else would we do during those long renders?
    ~jr
