Activity Forums Adobe After Effects Showreel for site – Best output for file size?
  • Showreel for site – Best output for file size?
    Posted by Gareth Hanks on October 2, 2006 at 2:37 pm
    Apologies if this should be in the Basics Forum but I have a question regarding a movie I will host on my web-site. My current showreel: https://fieldandpost.tv/workmotion.htm is just under 30 secs long but I want to effectively double this but without compromising on frame size (currently 288 x 162) nor double the physical file size (2.68mb)
    What is my best option to get a detailed image with an okay frame rate that will can play from a decent file size when outputing? I have not had any formal web training (hence my standard looking web-site) so this kind of info might be basic to some but I need some pointers.
    Thanks.
    Reloaded replied 19 years, 11 months ago 4 Members · 5 Replies
  • Steve Roberts
    October 2, 2006 at 2:41 pm
    I’d hit the compression techniques forum for this one.
    You could also search the COW for “sorenson” and “web”, just for some ideas.
  • Reloaded
    October 2, 2006 at 8:44 pm
    Man, you really need to improve your demoreel’s audio quality. It’s better a bigger file sith good audio than a smaller, but bad audio quality.
    Just my opinion.
  • Gareth Hanks
    October 2, 2006 at 9:40 pm
    Right, er…. thanks for that. I’ll bear that in mind.
    Thanks for the heads-up Steve on where to look. I only come here for the AE forum (shame on me!) so it’s just knowing where to turn & what to search for. I’ve now got good some pointers, I seem to have been heading in the right direction, so I can go back & make it longer with a slightly larger window.
    Cheers.
    Home – QuickSilver Duel 1Ghz 10.3.9 – 1.5 GB DDR SDRAM – 120Gb HD – AE 6.5
  • Curtoid
    October 3, 2006 at 1:35 am
    Just wanted to say that it looks like you’re doing some great work! I didn’t really have a problem with the audio at all, and actually liked it quite a bit. Keep up the good job!
    Steve Curtis
    HP Corporate Laserjet Division
  • Reloaded
    October 3, 2006 at 1:08 pm
    You work is really good.
    For professional compresssion take a look at Sorenson Squeeze.
    https://www.sorensonmedia.com/
