Activity › Forums › Adobe Premiere Pro › Showing Waveform With Applied Effects?
  • Showing Waveform With Applied Effects?
    Posted by Brent Taylor on June 3, 2015 at 10:04 pm
    Short version:
    Is there a way to get the waveform in Premiere to represent the waveform WITH the effects you’ve applied?
    Long version:
    I edit a lot of audio for videos in Premiere. Lots of people talking. Sometimes someone has a lot of volume spikes with their P’s or other consonants, or just stray words that are too loud. I’ll use a few techniques to even this out, but often just a compressor or limiter does the trick. I could work faster if the actual waveform showed up because I could get a better idea of how much things are being evened out at a glance.
    Brent Taylor replied 11 years, 3 months ago 2 Members · 2 Replies
  • Richard Herd
    June 4, 2015 at 10:14 pm
    [Brent Taylor] “epresent the waveform WITH the effects you’ve applied?”
    Not unless you render and reimport.
    Also please note audition has some tools more suited to plosives and hisses and a very good way to deal with Automatic Gain that many dSLRs use.
  • Brent Taylor
    June 10, 2015 at 10:04 pm
    I found the answer to this and thought I’d share for anyone who comes after.
    Right click > Render and Replace does what I was looking for. You can also nest things first if effects need to be applied to a few bits of audio at once more easily.
