Activity Forums Maxon Cinema 4D Showing only what’s in a cube
  • Showing only what’s in a cube
    Posted by Boris Wilmot on October 12, 2014 at 3:51 pm
    Hello all,
    I have a quite simple need but cannot find the right way to do it.
    I have a scene, and I only want to see what is inside the borders of an (imaginary) cube.
    I tried to make a cube with a transparent material, and put a compositing tag on my scene. I switched off the “seen by camera” and switched on the “seen by transparency”. The result is almost good, except that I can see what is behind the transparent cube when I only want to see what is inside the borders of my cube.
    any help?
    Boris Wilmot replied 11 years, 11 months ago 1 Member · 1 Reply
  • Boris Wilmot
    October 12, 2014 at 6:42 pm
    Got helpde on another forum.
    Simply had to use a Boole object !
    A noob has to learn 😉
