Activity Forums Adobe After Effects Showing audio waveform in layer
  • Showing audio waveform in layer
    Posted by Victoria Murphy on June 22, 2009 at 7:02 pm
    Hi. I am placing markers in an audio layer and comp; I would like to view the audio waveform in the audio layer so I can fine tune where I place the markers. Can I do this After Effects (CS3)?
    Thanks.
    Kalleheikki Kannisto replied 7 years, 7 months ago 8 Members · 11 Replies
  • 11 Replies
  • Victoria Murphy
    June 22, 2009 at 8:25 pm
    Thanks, Dave.
    Victoria
  • Andre Gomes
    November 8, 2012 at 7:20 pm
    Awesome!
  • Gergely Laszlo-zwickl
    December 22, 2012 at 7:41 pm
    Thank you, Dave!
  • Daniel Waldron
    February 23, 2013 at 7:42 pm
    Hold Command to scrub through the audio too.
  • Joshua Casper
    February 1, 2015 at 8:08 pm
    Is there a way to generate that waveform in the project itself?
  • Daniel Waldron
    February 1, 2015 at 8:51 pm
    Drop the Audio Waveform effect on a solid.
  • Jeremy Dance
    January 31, 2019 at 5:55 pm
    Actually I think the question is a little bit different. You are talking about two different things. The audio waveform effect generates a dynamic effect based on the sound at the current time. However I believe the question is referring to the static waveform you see when you twirl down the audio. Is there a way to create that image (static – peak file essentially) in an after effects project?
  • Richard Garabedain
    January 31, 2019 at 7:45 pm
    Why are you going back so far and posting on really old questions
  • Jeremy Dance
    January 31, 2019 at 9:28 pm
    For me it is a current question. I’d like to know how to generate a static peak file that I can use to show progress through a song.
  • Jeremy Dance
    January 31, 2019 at 9:29 pm
    And because these forums are searchable. Most of the time the questions I’ve had in after effects have been answered by threads that are old.
