Activity Forums Adobe After Effects Expressions Show or hide a layer in After Effects (Without using Opacity)
  • Show or hide a layer in After Effects (Without using Opacity)
    Posted by Andy Troz on August 5, 2013 at 3:32 pm
    Hello again!
    Sorry for the constant questions, but is there a script or expression to show or hide a layer in After Effects (via the “eye” checkbox)?
    Best,
    Andy.
    Dan Ebberts replied 10 years, 5 months ago 3 Members · 7 Replies
  • 7 Replies
  • Dan Ebberts
    August 5, 2013 at 5:29 pm
    You can’t do it it with expressions, but with scripting it would be like this:
    myLayer.enabled = false;
    Dan
  • Geof Gagnon
    March 13, 2016 at 6:40 am
    Hey Dan, I’m currently having a problem and I can’t get this expression to work. My syntax is:
    var path = "~/Desktop/fireball.png";
    var io = new ImportOptions(File(path));
    if (io.canImportAs(ImportAsType.FOOTAGE)){
    io.importAs = ImportAsType.FOOTAGE;
    io.sequence = false;
    io.forceAlphabetical = true;
    var sequence = app.project.importFile(io);
    sequence.name = "importA";
    var myComp = null; // assume the worst
    for (var i = 1; i <= app.project.numItems; i++){
    if ((app.project.item(i).name == "importA")){
    myComp = app.project.item(i);
    break;
    if (myComp != null){
    app.project.activeItem.layers.add(myComp);
    no matter where I put the expression to disable the layer, it doesn’t seem to do it’s job. Any ideas? Thanks.
  • Dan Ebberts
    March 13, 2016 at 7:47 am
    Sorry–I’m confused. You mention an expression, but you posted a script. What is that you’re trying to do exactly?
    Dan
  • Geof Gagnon
    March 13, 2016 at 7:43 pm
    Sorry, it’s actually a script. On button click I create a solid, add particle world to it, then import a png file, add it to the composition, and then I’d like to hide it. I believe the reference to the .png by the time it reaches the composition is myComp. But I’m unable to disable it.
  • Dan Ebberts
    March 13, 2016 at 8:44 pm
    Ah, OK–try this:
    var myLayer = app.project.activeItem.layers.add(myComp);
    Dan
  • Geof Gagnon
    March 13, 2016 at 8:49 pm
    Worked like a charm, you’re a king among men Dan.
    If you don’t mind me asking, what was the problem? It just needed to be assigned to a variable?
  • Dan Ebberts
    March 13, 2016 at 9:34 pm
    Actually, you could have done it in one step like this:
    app.project.activeItem.layers.add(myComp).enabled = false;
    which would create the layer and disabled it. The key is that you have to apply the .enabled = false to a layer object. I’d probably first put the layer object into a variable (like my example) and then disable it, just for clarity.
    Dan
