Activity Forums Apple Motion Show inner edges of window in 3D wall
  • Show inner edges of window in 3D wall
    Posted by Don Eitner on September 25, 2011 at 7:02 pm
    I’m new to Motion (5) but have watched many tutorials and have successfully created a handful of very simple 2D projects. What I am trying to do now is to create a 3D wall (with z-space thickness) which has a window which I can dolly the camera through as if the viewer is walking toward it. I have this working using a Color Solid as the wall with a mask shape added to lay out the window. I can “see” through the window what is on the other side (a video layer set back in z-space from the wall) however there are no “inner edges” to the window, it’s just a flat plane.
    I created a replicator on the wall, set it to replicate in a line and increased the number of points. When I orbit the camera around I can see the wall has thickness and appears solid, but dollying the camera through the window still doesn’t show the inner edges (the z-space edges) of the window.
    Any suggestions? Thanks in advance.
    Don Eitner replied 14 years, 11 months ago 2 Members · 2 Replies
  • Mark Spencer
    September 26, 2011 at 12:48 pm
    Rather than using a replicator, I would “build” each side of your wall to create thickness the same way you would build a cube – by rotating and placing planes in 3D space.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Don Eitner
    September 27, 2011 at 12:31 am
    Thank you Mark, I will try that. My window was non-rectangular (rounded top) which is why I used an image mask to cut it out of the wall. I’ll need work out how to build a curve with depth for that top edge, or else try not to be so fancy on my first try. 🙂
