Activity Forums Adobe After Effects Expressions Show/Hide Properties with Keyframes
  • Show/Hide Properties with Keyframes
    Posted by ali kim on November 11, 2024 at 2:43 pm
    I have an extension the executes this function to show/hide properties with keyframes:
    function test() {
    var res = false;
    var msg = ‘default’;
    var comp = _proj.activeItem;
    if (!comp || !(comp instanceof CompItem)) {
    msg = ‘No active item or active item is not a comp’;
    return toJSON(res, msg);
    var layer = comp.layer(1);
    if (!layer) {
    msg = ‘No layer selected’;
    layer.selected = true;
    var cmdStr = ‘Reveal Properties with Keyframes’;
    var cmdId = executeCommand(cmdStr);
    if (cmdId == 0) {
    msg = ‘Command \” cmdStr ‘\’ id not found’;
    msg = ‘Executed \” cmdStr ‘\’ (‘ cmdId ‘)’;
    layer.selected = false;
    function executeCommand(cmdStr) {
    var cmdId = 0;
    cmdId = app.findMenuCommandId(cmdStr);
    if (cmdId == 0) return cmdId;
    app.executeCommand(cmdId);
    return cmdId;
    }When I call test() the first time, it works and opens keyframed props, but when I call it again, it opens all props of the layer. On the other hand, if after the first call I click away from the extension window and focus AE UI, it work and hides keyframed props.Does anyone here have any experience re this behavior?
    ali kim replied 1 year, 9 months ago 1 Member · 0 Replies
  • 0 Replies
