Activity › Forums › Maxon Cinema 4D › Show All Animated (Keyframes)
Posted by Mike Lister on April 7, 2008 at 3:06 pmHi all,
In 9.5/9.6, you had the ability to “Show all animated” keyframes in the Timeline.
Is this possible in 10.1/10.5?
thanks
Brian Jones replied 18 years, 5 months ago 3 Members · 4 Replies -
Mike Lister
April 7, 2008 at 10:54 pmBrian,
thanks for this…but this only seems to work when you hilight something in your Object palette.
i hope this makes sense.
i know if 9.6 you could just click in the timeline and hit show all keyframes w/o hilighting anythign in the oject palette.
it saved time when you can’t really remember where your keyframes are set.
Adam Trachtenberg
April 8, 2008 at 12:33 amThere are a few extra steps in 10+. You have to have both “show animated” and “automatic mode” activated. Even then it won’t show material and some other tracks by default. You have to go to the TL’s view menu and select “one level up” or “main level.”
AdamT
Cinema 4DXL8 Bodypaint*Remember: Tues. is national Shoe Day. Wear shoes to show your support for bimetalism and the designated hitter rule!*
Brian Jones
April 8, 2008 at 1:19 amHopefully I’m not stating the obvious here but also be aware that Show Animated (with Automatic Mode on) toggles between showing all objects in the scene and only the animated ones. With Automatic Mode off you have drag the object in (or right-click/Animation/Show Track) to see keys/curves.
