Activity › Forums › Apple Final Cut Pro Legacy › Shouldn’t this be fast?
Posted by Infomanbri on July 30, 2007 at 9:32 pmHello all,
My company recently upgraded from a souped up G4 to a brand new Mac Pro:
(2.00 GHz Dual-Core Intel Xeon, 4 GB RAM, NVIDIA GeForce 7300 GT, 2x LaCie Firewire d2 Extreme – one for Project Files/Media and the other for Backup, 1x FANTOM 500GB Video drive)
We’re running the latest version of Final Cut 5.1.4 and FCP Studio 1.
My question to the Cow geniuses: shouldn’t this setup be smoking fast? Don’t get me wrong, it’s much faster than the G4, but I don’t find it too much faster than my personal Single Processor G5!
Any system optimization techniques I am missing?
Jeremy Garchow replied 19 years, 1 month ago 3 Members · 11 Replies -
Infomanbri
July 30, 2007 at 10:17 pmSorry, I guess I should have clarified that. Basically, I was surprised at how slow the render times were. I would think RT Extreme would especially be faster.
Jeremy Garchow
July 30, 2007 at 10:23 pmRender times of what, to what kind of codec and with what kind of effects?
RT extreme also has a lot to do with your scratch drives (of which, none of yours are particularly fast). If you had at the very least a two drive SATA array (even striped within your MacPro) you will see some increase in speed.
Your computer should be rendering faster than a G4, if not perhaps you have something wrong with your shiny new machine.
Walter Biscardi
July 30, 2007 at 10:27 pm[InfoManBri] “I would think RT Extreme would especially be faster.”
Not with those harddrives you listed. You’re running fairly slow FW800 drives. RT is wholly dependent on drive speed. Run a very fast SATA or Fibre Channel array and you’ll have a ton of RT effects. We’re purchasing a pair of SAS/SATA arrays that top out at almost 500MB/s and give us a ton of RT, even in HD work.
Also, if you upgrade the Graphics card to an ATI 1900, that helps RT as well, especially for FX Plugs.
Processors kick in for faster rendering times, not RT Extreme.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Infomanbri
July 30, 2007 at 10:31 pmThat’s the thing, we’re just working in SD, with some fairly complex Motion projects mixed with video on the Final Cut timeline.
Walter Biscardi
July 30, 2007 at 10:34 pm[InfoManBri] “That’s the thing, we’re just working in SD, with some fairly complex Motion projects mixed with video on the Final Cut timeline.”
Doesn’t matter, RT Extreme is based on harddrive speed. Uncompressed SD has larger file sizes than DVCPro HD for example so you would actually get more RT running DVCPro HD than Uncompressed HD.
If those Motion projects have Alpha Channels, that’s not realtime.
Jeremy Garchow
July 30, 2007 at 10:49 pmThere also seems to be a bug in rendering Motion Projects from the timeline in FCP6.
Search this forum for Motion render and you will see all the problems.
Infomanbri
July 30, 2007 at 11:23 pmThanks, I will remember that as I have recently purchased FCP Studio 2 for myself! But what about in Final Cut 5? At work we are using FCP 5.1.4 w/ Motion 2. Shouldn’t this combination run smoothly?
Infomanbri
July 30, 2007 at 11:28 pmSo, what’s a good hard drive speed for better RT results? Isn’t 7200RPM the standard issue with Mac Pros?
Thanks for all of your help!
Walter Biscardi
July 30, 2007 at 11:39 pm[InfoManBri] “So, what’s a good hard drive speed for better RT results? Isn’t 7200RPM the standard issue with Mac Pros?”
That’s just the RPM. Drive speed is the data rate transfer as in 50MB/s, 100MB/s, etc….. The faster this speed, the better the RT in any version of FCP.
A single drive will be very slow compared to a SATA or Fibre Array that contains 5 – 14 drives all striped together. Our arrays will be 8, 1TB 7200 RPM drives striped together for almost 500MB/s, that’s two streams of uncompressed HD or 16 streams of DVCPro HD.
