Activity Forums Apple Final Cut Pro Legacy shouldn’t our new Xserve RAID be faster?
  • shouldn’t our new Xserve RAID be faster?
    Posted by Andrew King on November 10, 2006 at 8:52 pm
    Just installed a Xserve RAID 7x500gb on 1 channel as RAID 5
    Shouldn’t we be able to capture Uncompressed SD?? the system is dropping frames.
    Andrew
    Andrew King replied 19 years, 9 months ago 5 Members · 5 Replies
  • Chris Borjis
    November 10, 2006 at 10:21 pm
    have you run a disk speed test?
    what are the results.
    is this a 2gb fibre or 4gb fibre setup?
  • Aaron Neitz
    November 10, 2006 at 10:34 pm
    There’s something very wrong. you should be able to capture SD no problems with 1 LUN of 7 disks.
    Is this an XRAID straight into a G5? No SAN, anything like that? How did you format the raid – with the xraid utility or disk ultility?
  • Peter Wiggins
    November 10, 2006 at 11:50 pm
    Don’t allow host cache flushing?
    Peter
    Free Motion Templates
    peterwiggins.com
  • Bjørn Holmgren
    November 11, 2006 at 3:46 pm
    It can take a long time to build the raid – mine took over 24 hours. The throughput increases a lot when the build is finished.
  • Andrew King
    November 14, 2006 at 3:00 pm
    After the weekends rest it seems to be working… thanks for the tips!
    -Andrew
