Activity Forums Apple Final Cut Pro Legacy Should my Kona2 card give me a performance boost for DV Playback?
  • Should my Kona2 card give me a performance boost for DV Playback?
    Posted by Basem Elsokary on February 9, 2006 at 7:22 pm
    So I bought a Kona2 card to work on some HD projects…
    The thing is, I thought I would be able to use the Kona card to help take some “pressure” off the CPU in terms of playback quality when applying effects/filters/etc to regular SD DV material on the timeline. Right now however, if I use any of the Kona settings, I seem to actually need to render more stuff than I would had I just used FCP’s standard settings.
    Any idea on what I may be doing wrong? Am I expecting too much from this card?
    Joseph Bradley replied 20 years, 7 months ago 2 Members · 1 Reply
  • Joseph Bradley
    February 10, 2006 at 12:14 am
    yes you are. The kona 2 is a capture card. What you need is a great Graphics card. It is the graphics card that has a proc on it that can do a lot of the work the computers proc does. The Kona 2 lets you capture with more codecs and it also can take a 525i clip and upres it to HD and it can down res HD as well.
