Activity › Forums › Adobe Premiere Pro › Should I use Premiere or Flash?
  • Should I use Premiere or Flash?
    Posted by Chris Leonard on December 10, 2007 at 10:34 pm
    I have a new project that involves taking a Powerpoint presentation and converting it over to something more powerful, like Premiere. I will also be adding some special effects that bring it closer to broadcast quality video/animation, so I may use After Effects as well.
    I went ahead and took all of the images/video files out of Powerpoint and put them into Premiere. The final video needs to be 1280 x 720 and 30 fps at about 10 minutes long, so the file sizes were large, and took several hours to export to avi.
    I recreated this project in Flash, and it takes only minutes to export, and the file size is much smaller. (These videos are going to display as loops on monitors in Doctors waiting rooms, the monitors are connected to a computer at the Drs office). Im curious if it would be a good idea to do this video compilation in Flash, or if Flash has limitations with this kind of thing that would make Premiere/After Effects a better choice?
    Chris Leonard replied 18 years, 9 months ago 2 Members · 2 Replies
  • Lex Park
    December 14, 2007 at 4:34 pm
    You can achieve basically the same results (video quality-wise) going either route. I think it depends on a few things:
    Which program(s) are you most fluent at?
    If you know Flash well enough to build the whole thing there, then you’ll have a great looking final result with a small file size.
    If you know AE and PP better and can get it done there with less of a learning curve or whatever, then go that route.
    The only thing you’ll be missing is any interactivity that Flash provides. But since this will just be something to watch and not play with, then AE and PP can do it.
    – The Foonshoe
  • Chris Leonard
    December 14, 2007 at 5:53 pm
    Thank you for the great reply!
