Activity › Forums › Adobe Premiere Pro › Should I upgrade to PP 2, CS3 or go to elements?
  • Should I upgrade to PP 2, CS3 or go to elements?
    Posted by George Mcnair on December 21, 2007 at 4:32 am
    I have been using PP 1.5 and should I upgrade to PP2 since I’ve heard problems with PP CS3?
    Maybe Adobe element will be better.
    The last frustrating video I made with PP1.5 had the audio out of sync with the video. Encoding to Mpeg 2 DVD and burnig with Nero had the video jumping to audio sounds, so I just burn using SVCD which works fine.
    For now I want to make 30 minute basic videoes that will play on most DVD players. Will PP 2 do the job simply?
    Mike Velte replied 18 years, 9 months ago 2 Members · 1 Reply
  • Mike Velte
    December 21, 2007 at 11:52 am
    2.0 is a bit simpler for making DVDs as 3.0 will require you to learn a bit about Encore which is included. I dont think you can get 2.0 any longer.
    Elements is better if you are editing already compressed video and it is quite simple.
