Activity › Forums › Panasonic Cameras › Should I mix HVX200 footage with DVX100 footage in documentary?
  • Should I mix HVX200 footage with DVX100 footage in documentary?
    Posted by Jeremy Wiles on July 18, 2006 at 6:50 pm
    I shot a documentary on the Panasonic AG-DVX100. I was planning to purchase the HVX200 to shoot the opening scenes for the film, which include some underwater stuff that I thought would look really cool in HD.
    I have several concerns before making the purchase:
    1. Will it be a huge noticeable difference going between HD 24p and 24p shot on the dvx100 during the film?
    2. Will there be any problems editing both SD and HD footage on the same timeline?
    3. Is the only way to obtain HD footage by recording to the P2 cards? From what I’ve read, the dv tapes only record 25mbps, is that correct?
    4. What would you do in my case? Would you continue to shoot the film with the DVX100 or switch over to the HVX200 to obtain HD footage?
    Just to note, the scene that will be shot with the HVX200 will be over 10 minutes long in the final video and would not not jump back and forth between HD and SD footage every 20 seconds. It may go 10 minutes HD and then 10 minutes SD.
    Jeremy
    http://www.BibleTreasureFilms.com
    Gene Brockhoff replied 20 years, 2 months ago 2 Members · 1 Reply
  • Gene Brockhoff
    July 22, 2006 at 7:32 pm
    I have a similar concern, and it depends on many factors. First one is weather you bump the SD up to meet the HD and what you use to do it with. I understand that FCP5 has a nice scaler to make 480p a good match to 720p. The jump to 1080 would be too much for SD to look good. You will notice a difference in the SD looking softer, but as you say, you will not be jumping back and forth so that works in your favor. There are some other “uprezzers” out there. One that comes to ming is InstantHD. But if you got FCP5, the uprezzing is free. The other factor is, what is the distribution? If you know that it’s going to a film print, then by all means shoot the best you can get, but for a dvd or tv the added cost may not be worth the upgeade.
