Activity Forums Apple Final Cut Pro Legacy Should exporting take this long? Best Method?
  • Should exporting take this long? Best Method?
    Posted by Derek Bowshier on September 1, 2010 at 4:58 pm
    I recently made the mistake of shooting a series of 20 hour long lectures with my ex3. The mistake was I unnecessarily shot in full 1080p.
    Now when I’m trying to export as a quicktime movie H.264 (downconvert to 720×480) it’s taking 5-6 hours for each export.
    My MacPro has duel 2.8 Quad-core processor with 6GB 800mhz ram.
    Should it be taking this long when all i’m trying to get is a SD version of these?
    Is there a better exporting method that will speed up the process significantly, when quality is not top concern. I would still like them to look good, just doesn’t have to be HD perfect.
    When I export as a QT reference file each file is between 12-14GB a piece. I need to compress and fit as many as I can onto a DVD.
    John Fishback replied 15 years, 12 months ago 3 Members · 2 Replies
  • Ron Pestes
    September 1, 2010 at 5:17 pm
    Try sending the timeline to Compressor. There is a preset for standard definition that should be faster.
    Apple Certified Master Pro FCS 2
    Sony EX-3
    MacBook Pro
  • John Fishback
    September 1, 2010 at 7:58 pm
    Compressor encodes mv2 and ac3 files for a DVD faster than real time on my 8-core machine. You can adjust the encode bit rate in Compressor so you can fit four hour-long programs on one DVD at better than VHS quality. However, IMHO, BitVice will do the very best low bit rate encodes.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
