Activity Forums Apple Final Cut Pro Legacy Should Blu-ray Discs burned fr FC to Toast 9 be 480P?
  • Should Blu-ray Discs burned fr FC to Toast 9 be 480P?
    Posted by Thomas Hughes on August 29, 2014 at 5:31 pm
    We cut on FC then burn to Blu-ray Disc using Toast 9 using the default Blu-ray Disc settings at the highest quality. When I playback the Blu-ray Disc on a tabletop player, it says it’s 480P. Is that what it should be? If not, is there a way to tell Toast 9 to do it at 1080P? Also since it’s at 480P, I tried playing it on an SD DVD player but it doesn’t play. Any help is appreciated. Tx
    Thomas H
    Thomas Hughes replied 12 years ago 1 Member · 0 Replies
  • 0 Replies
