Activity › Forums › Adobe After Effects › should be a simple expression
  • should be a simple expression
    Posted by David Markey on July 11, 2012 at 10:14 pm
    Hi All,
    Need help with a simple expression. I have an Offset effect on a layer. I want the x value of the shift center property to stay constant, but I want the y value to increase over time.
    shouldn’t it be something like this?
    [value, time*100]
    that doesn’t work. I should be able to figure this out, but my brain isn’t working.
    Darby Edelen replied 14 years, 2 months ago 2 Members · 1 Reply
  • Darby Edelen
    July 12, 2012 at 12:07 am
    [David Markey] “[value, time*100]”
    Value is a vector/array on a position property. You have to specify which component you want:
    [value[0], time*100]
    Darby Edelen
