Activity Forums Audio Shotgun microphone, 40m XLR cable, Tascam portable recorder, input & output impedance
  • Shotgun microphone, 40m XLR cable, Tascam portable recorder, input & output impedance
    Posted by Mano Kneisser on January 10, 2013 at 1:21 pm
    Hello,
    i need to record audio for a short film using Tascam DR-40 and one of the shotgun listed below.
    Audi-technica AT8035 or AT8015: output Impedance = 500 Ω
    Rode NTG-2: output Impedance = 250 Ω
    Azden SGM-1000 output Impedance = 1500 Ω
    Azden SGM-1X output Impedance = 680 Ω
    for a wide shot scene, i will need to place the camera (5DMKII) 40 meters away from the talents and connect the shotgun to the tascam with a 40m long XLR cable
    the tascam DR-40 will be connected to my camera with a sescom cable .
    (off topic: the talents will have lavalier mic connected to Tascam DR-05)
    so i was reading that, the highest the output Impedance of the mic, the highest the signal loss when using a long XLR cable.
    since the Input Impedance of the Tascam DR-40: = 2200 Ω
    the questions is :
    -is the Rode NTG-2 the most suitable mic for this kind of situation ? (aside from the mic quality)
    – is it better to equalize the Input/output inpedance ? and if yes, how?
    thanks in advance for your input
    Ty Ford replied 13 years, 8 months ago 2 Members · 1 Reply
  • Ty Ford
    January 11, 2013 at 1:42 am
    Hello Mano and welcome to the Cow Audio Forum.
    Gross differences in impedance can show losses, but here, not so much. However the Mk ii has crappy audio. I wouldn’t use it for production anyway. I hear the mk iii is much better.
    But, you need a phantom supply and the correctly wired cable to put the audio to the correct pins in the camera input.
    The NTG-2 runs on a battery, so you wouldn’t need a phantom supply, but you’d still need a specific cable. Also with no mixer and limiter, you can’t control the audio level while shooting. You will probably need to do that.
    Regards,
    Ty Ford
    Cow Audio Forum Leader
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Ty Ford Blog: Ty Ford’s Blog
