Shot vid 30fps asf, how to change preview 29.97 to 30?
Hello,
I shot vid at 720X480 30fps asf. The audio and video don’t sync correctly when rendered since the default setting in vegas pro 8 is 29.97. I’m not having luck finding the setting to change the rendering or preview settings to 30fps instead of 29.97.
If you right click the preview screen you can’t change it to 30 fps. Can someone help out?John
