Shot Varicam 23.98 so I capture that way as well, right?
shot DVCPRO HD 720 23.98.
So, in “easy setup” i should choose 720p 23.98 DVCPRO HD varicam, correct?
I know the Varicam shoots 60 frames or 59.94 per second and flags the 23.98 (that you actually see). Why wouldn’t I capture 59.94 then? Is there some info on the other (non-seen frames… like timecode) that’s needed?
