Activity › Forums › Adobe Premiere Pro › Shorten both transition ends at once?
Posted by Lois Heckland on March 19, 2010 at 7:10 pmIs there a way to shorten both ends of a transition (like cross dissolve, or dip to black) symmetrically and at the same time? It seems inefficient to drag each end in separately. Thanks!
Lois Heckland replied 16 years, 6 months ago 2 Members · 4 Replies -
Jeff Pulera
March 19, 2010 at 11:44 pmClick on the transition, which opens up the Effects Controls for the transition, then simply click and drag on the timer in the Effect Controls (or manually enter a different value, but mouse is quicker).
Jeff Pulera
Safe Harbor Computers -
Lois Heckland
March 24, 2010 at 12:58 amThat doesn’t seem more efficient than just clicking on each end of the transition right on the timeline. Is it better in other ways?
Jeff Pulera
March 24, 2010 at 2:31 pmIf you wish to manually drag the ends of the transition to lengthen or shorten, first you likely need to zoom in closer to get any decent control, so that takes time. Next, you have to click and drag BOTH ends of the transition one at a time, and watch the little counter to take equal frames of each end (that was the original question, keeping it symmetrical).
To me, it it way easier and faster to make a single click on the transition (without needing to zoom in first)to select it, then right above it, in the Effects Controls, click and drag the timer greater or less, done. Two quick clicks.
Maybe there’s another way or a keyboard shortcut, I certainly don’t know everything, but seems pretty fast and easy to me.
Jeff
Lois Heckland
March 25, 2010 at 7:09 pmThat was pretty convincing, thanks.
It’s likely that Adobe just doesn’t have the ability to do it on the timeline.
