Activity Forums Apple Final Cut Pro Shortcuts in the Viewer?
  • Shortcuts in the Viewer?
    Posted by Andreas Zeitler on August 31, 2012 at 6:51 am
    Hello everyone,
    I was looking around for shortcuts in the Viewer and all I could find was “shortcut to highlight the Viewer”, which was not what I’m looking for. Are there any shortcut to position clips with the keyboard? That would be very helpful. Thanks.
    Side question: Would it be possible to search for these things in the Command Editor? If yes, how?
    Thanks in advance,
    Andreas
    Andreas Zeitler replied 14 years ago 2 Members · 2 Replies
  • Andrew Hays
    September 6, 2012 at 4:30 am
    are you referring to the selecting clips in the viewer? if so, as far selecting the viewer, the arrow keys should allow you to select clips. If you hit Command-1, then use up or down arrow keys, you’ll be able to select favorites, etc within the clips.
  • Andreas Zeitler
    September 10, 2012 at 10:06 am
    No, I meant moving the video in the viewer pixel-by-pixel up/down/left/right.
