Activity › Forums › Avid Media Composer › Shortcut to turn audio tracks on and off???
Posted by David Oulashian on January 27, 2006 at 12:47 amHi,
Can someone please tell me that there is a shortcut to turn individual audio tracks on and off (he hopes . . .) — I don’t mean a shortcut to select the tracks, rather to enable the little speaker icon.
David Oulashian
David Oulashian replied 20 years, 7 months ago 4 Members · 7 Replies -
David Oulashian
January 27, 2006 at 5:52 amBustin’ my chops, eh? 😉 Okay, so the second question should have been “if so, what is that shortcut?”
Thanks a lot,
David
Matt
January 27, 2006 at 1:18 pmguilty your honor. You can try using the Alt modifier while pressing the 9 or 0 key on main keyboard. That should do it. And you are right- there’s
no track SOLO shortcut. (they make you Ctrl + click the speaker icon). -
David Oulashian
January 27, 2006 at 7:35 pmOkay so [Alt] plus [9] or [0] does seem to turn on and off audio 1 and audio 2 but what about the other 6 audio tracks I have in my timeline?
FYI I am on an Adrenaline 1.6
Thanks a lot.
David Oulashian
Ronen
January 28, 2006 at 4:24 pmyou can map you keys to your keyboard.
ctrl+3 to open the plate, and than drag and drop to your keyboard settings
[under settings double click ‘keyboard’]
I use keys 9,0 – + and F9-12 to map A1-A8 -
Joe Womble
January 31, 2006 at 9:44 pmOr, you can do the obligatory Shift+Ctrl+A to deselect ALL tracks. Ctrl+A to select all tracks.
Or, Shift+drag mouse over all the tracks from top to bottom or bottom to top to select/deselect tracks.
Cre8tive
David Oulashian
February 1, 2006 at 7:04 pmActually, I wanted the shortcut to enable a track audio (turn on the speaker icon) not select the tracks themselves. [Alt] plus the audio track shortcut seems to work.
David
