Activity Forums VEGAS Pro Shortcut to slice clip into multi slices of equal length?
  • Shortcut to slice clip into multi slices of equal length?
    Posted by Luke Gibson on July 18, 2017 at 7:32 pm
    I’ve got several clip that’s about 3 or 4 minutes long and I’m trying to edit for a simple music video, I’ve set the ruler to 210bpm and grid lines every 8th note, I want to split the track into equal lengths every two, three or six 8th notes along the grid.
    In Cubase/Nuendo, the splitter tool + alt key divides into equal slices relative to the selected point and the clip start and would slice the entire clip in one click.
    It’s hundreds of slices and the slice tool doesn’t seem to snap even with all snapping enabled, so really hope there’s an easy solution without having to do it all by hand?
    p.s. I’d be happy if there’s a way to short key jump to the position of the next slice, just want to avoid having to position each slice manually with the mouse.
    Luke Gibson replied 9 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
