Activity Forums Apple Final Cut Pro Legacy Shortcut searching the markers of the bin
  • Shortcut searching the markers of the bin
    Posted by Shermen Chan on January 28, 2014 at 5:24 am
    In FCP 7,I’m used to adding markers in the clips from the bins. When I want to find the markers through command F, it didn’t show any, and it only shows when I put the related footage on the sequence timeline, so it’s a bit frustrated if I do it every time with tons of footage day by day. Is there any short cut I can directly find the markers I’ve inserted in the clips from the bins ?
    Thank you
    Nick Meyers replied 12 years, 7 months ago 2 Members · 1 Reply
  • Nick Meyers
    January 28, 2014 at 10:48 am
    the clip makers are only searchable in the timeline,
    OR in the browser if you have the clip’s discloser triangle open, so the markers are visible.
    an old and rather big drawback in FCP’s functionality.
    you might want to take a look at Final Print from Digital Heaven
    https://www.digital-heaven.co.uk/finalprint
    nick
