Activity › Forums › Adobe After Effects › shortcut help !!!!
  • shortcut help !!!!
    Posted by Aroonzfx on August 1, 2005 at 7:35 pm
    hey
    1. is there any shortcut to set the opacity to different values other than by typing in different values ..
    in photoshop if we type 50 then the opacity of the layer is reduced by half
    similarly is tehre any such shortcut in ae ?
    2. is there any shortcut to access the transfer modes inside of the
    a particulr plugin..
    for eg// while applying shine, we can choose diff transfer modes..
    so if i hav to chooose screen , iwill have to go to the effects controls .. and then choose screen, and it takes more time while expirementing ..
    is there any shortcut for it
    thnx
    aroonz
    Aroonzfx replied 21 years, 2 months ago 2 Members · 2 Replies
  • Filip Vandueren
    August 1, 2005 at 9:25 pm
    1. the fastest you can do is type Ctrl-shift-o (Opacity), type 50, then return. Not the way Photoshop does it, but reasonably fast.
    Also ctrl-shift-R, ctrl-shift-P for rotation and position
    2. no, keyboard shortcuts are not passed through to effects, except the ones that take overthe whole screen I think.
  • Aroonzfx
    August 2, 2005 at 6:53 pm
    THANX FILIP
    THANX A LOT
    AROOONZ
