Activity Forums Adobe After Effects Shortcut for staggering the beginning of layers in timeline
  • Shortcut for staggering the beginning of layers in timeline
    Posted by Tyler Yowell on July 18, 2007 at 2:14 am
    Annoyingly simple question-since AFX doesnt have it so two pieces of footage snap together when near each other, I need to know how to do that. So then-how do I stagger layers so that the end of one is exactly the beginning of the other?
    I remember seeing it in a tutorial somewhere, but I cant remember it at all.
    Thanks.
    Mark Fogarty replied 19 years, 1 month ago 5 Members · 7 Replies
  • 7 Replies
  • Andrew Kramer
    July 18, 2007 at 2:17 am
    https://library.creativecow.net/articles/kramer_andrew/slideshows.php
    select layers and rightl click and choose animation options “sequence layers” There are some options to overlap.
    Best,
    Andrew Kramer
  • Rutger
    July 18, 2007 at 2:24 am
    Staggering can be done by selecting the layers that you want to stagger. Then right-click and choose Keyframe assistant > Sequence Layers. Make sure that overlap is not checked and they should now line up nicely. I am not sure how to have layers move so that they automatically ‘snap’ to eachothers in or outpoints.
    Hope it helps.
    Rutger
  • Tyler Yowell
    got it, that very tutorial was where i originally saw it! it was under ‘keyframe assistant’ in the animation options menu. while we’re at it, something else that i had known how to do but now it has slipped my mind:
    the shortcut to align a layer(s) with the beginning of the comp.
    Thanks a lot.
  • Rutger
    July 18, 2007 at 2:29 am
    Looks like you got the same answer twice. Did not see Andrews reply yet when I started typing.
    Well, at least it works.
    Rutger
  • Andrew Kramer
    July 18, 2007 at 2:43 am
    Actually you had it right, I said animation but it is indeed keyframe assistant…
  • Steve Roberts
    July 18, 2007 at 10:49 am
    [cyowell] “while we’re at it, something else that i had known how to do but now it has slipped my mind: the shortcut to align a layer(s) with the beginning of the comp.”
    Select the layer, then hit Alt+home or Opt+home on Mac.
  • Mark Fogarty
    July 18, 2007 at 1:24 pm
    You can always hold the SHIFT key down while moving layers and they will snap to other layers.
