Activity Forums Apple Final Cut Pro Legacy shortcut for nudging a clip all the way over to adjacent clip?
  • shortcut for nudging a clip all the way over to adjacent clip?
    Posted by Paz Derien on August 3, 2011 at 4:43 am
    This is something I need do all the time and there must be an easy way but I can’t find a shortcut. Now that I am using a laptop more and more, i need more shortcuts!
    Okay, so sayI have two clips in my timeline with some space between them. I select one clip and nudge (comma key) it over to bump up against the other one. If I hold down shift, it moves faster. But what if I want it to just jump right over next to the other one without holding shift for ten seconds? Or click-and-dragging? I can’t ‘close gap’ because often there is another underlying audio track.
    I hope this question is clear, thank you for sharing your knowledge
    Jeremy Garchow replied 15 years, 1 month ago 3 Members · 8 Replies
  • 8 Replies
  • Jerry Hofmann
    August 3, 2011 at 1:14 pm
    You can still close the gap if you lock the underlying audio tracks. Would that work for you?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Jeremy Garchow
    August 3, 2011 at 8:45 pm
    Select the empty space and hit delete?
  • Paz Derien
    August 3, 2011 at 8:49 pm
    Thank you, I am trying to do this with minimal clicks so I don’t want to have to contstantly lock the underlying audio track, which I am often moving around. It would be less trouble to just turn on snap, click, and drag. I am trying to do this in ONE shot! Again thanks.
  • Paz Derien
    August 3, 2011 at 8:50 pm
    Thanks, this is what I do all the time and I am trying to find a shortcut instead of having to drag/snap. Sounds like there isn’t one.
  • Paz Derien
    August 3, 2011 at 8:51 pm
    Hi Thanks, That doesn’t work if there’s an audio track underneath.
  • Jeremy Garchow
    August 3, 2011 at 9:00 pm
    [Dia Felix] “Hi Thanks, That doesn’t work if there’s an audio track underneath.”
    Buy FCPx and use the magnetic timeline? HAHAHAHAHAHAHA! I kid, I kid.
    Shift f5 locks all audio tracks, select gap, delete, shift f5 to unlock.
    Or use close gap (control-g) after shift f5
  • Paz Derien
    August 3, 2011 at 10:59 pm
    Thanks, I’ll probably end up doing this. I do a lot of weird stuff involving double arrow left/deselect audio track/drag, your way is faster….again thanks
  • Jeremy Garchow
    August 3, 2011 at 11:09 pm
    I have no idea what your timeline looks like, but you do know that you can rewire keyboard commands to lock certain tracks, right? Hit option-j and then type lock in to the search bubble and assign away. That way you can easily lock the music tracks (or whatever) in place if need be.
    Jeremy
