Activity Forums Adobe After Effects Shortcut for “Create shapes from vector shortcut”
  • Shortcut for “Create shapes from vector shortcut”
    Posted by Maria Pixamins on April 29, 2016 at 3:56 pm
    Hallo I need to know if there is a shortcut for the “Create shapes from vector “.
    For the next days i will be importing hundrents of .ai files and transform them in shapes.
    If there is a shortcut it will save me tons of time.
    Maria Pixamins replied 10 years, 4 months ago 2 Members · 4 Replies
  • Cassius Marques
    April 29, 2016 at 5:54 pm
    If the command sits on any menu you can either:
    Add or change the shortcut to it by messing with the shortcuts file. SEE HOW
    If it ain’t there you can add a script to run it. Scripts can run any menu command. You can then place that script on AE’s script folder and you’ll be able to add a shortcut to it using the above method. You should google search for that.
    If it is only a context right click option. There’s no way you can add a shortcut to it as far as I know. (but this is not your case).
    Cassius Marques
    http://www.zapfilmes.com
  • Maria Pixamins
    April 30, 2016 at 7:29 am
    Thanks for guiding.
    Unfortunatelly searching the internet did not came up with more than “re-arranging” the shortcuts!
    I found nothing concerning the create a shortcut which is not provided!
    In case you came out with something I will be more than HAPPY.
  • Cassius Marques
    May 2, 2016 at 6:20 pm
    I wrote one to run the command. (its just a call for the item, you can edit if you ever need to do another).
    Download here 10040_01createshapesfromvectorlayers.jsx.zip
    You should place it in your AE folder under “\Support Files\Scripts”. The reason it has a “01” before its name is for it to be the first file on the folder. This way AE sees it under File->Scripts.
    All scripts there can be shortcutted under the “ExecuteScriptMenuItem01” in your shortcuts file.
    Make sure you don’t add a duplicate shortcut for it. Otherwise it will take precedence over this.
    Cassius Marques
  • Maria Pixamins
    May 3, 2016 at 6:53 am
    WORKED
    THANKS
