Activity Forums Adobe Premiere Pro **Short film project workflow advice needed ***
  • **Short film project workflow advice needed ***
    Posted by Shravan Ram on July 20, 2014 at 10:20 pm
    Okay so this is a 15-20 minute short film filmed over 3 days with around 65 GB worth of footage.
    Also,the audio was recorded using a TASCAM recorder + boom -so needs to be synced.
    Project needs to be completed in 3 weeks.
    No.of editors : 1
    What do you suggest ?
    Should I get an assistant editor to help me speed up the process? Especially syncing.. ( We used clapper-board)
    Best/Efficient workflow ?
    -First sync all audio-video rushes ? There are hundreds of video and audio files.
    – Once sync is done – start logging/adding metadata
    – Rough cut,etc..
    Also- I think the audio has been recorded on ‘mono’- single channel- this has to be changed to 2 channels ?
    Any advice will be appreciated !
    Thanks in advance !
    Shravan Ram replied 12 years, 2 months ago 1 Member · 1 Reply
  • Shravan Ram
    July 22, 2014 at 9:56 am
    So what do you suggest instead ?
