Activity › Forums › Apple Final Cut Pro Legacy › Short cut key
Short cut key
Posted by Jeffrey Levenstone on November 16, 2005 at 4:39 pmIs there a shortcut key to select from timeline to next cut left or cut point right.
Jeffrey Levenstone replied 20 years, 9 months ago 3 Members · 4 Replies -
Liam Stephens
November 16, 2005 at 4:53 pmHmmm once cut has been selected, up arrow to go left down arrow to go right
Jeffrey Levenstone
November 16, 2005 at 5:15 pmLet meexplain it better. I want when I press ctrl + v, that I can then press a short cut and select to the next cut point and then press delete. So this saves me using the mouse to select and delete.
Thanks in advance.
Annaël Beauchemin
November 16, 2005 at 6:51 pmyou can use “x” to mark in/out the clip and then use the delete or backspace key to delete it.
Btw, when you’re on a cut, the x key will mark the right side clip. You need to back off a frame to mark the left side clip.
