Activity Forums Apple Final Cut Pro Legacy short cut key stopped working
  • short cut key stopped working
    Posted by Debbie Smith on June 3, 2010 at 5:50 pm
    Hi, I use “control v” to make an edit. It has stopped working within a particular project. It works if i start a new project, but no longer in this one. I’ve tried duplicating sequences, starting new project and importing all media, nothing works.
    Does anyone have a solution other than trashing preferences? That doesn’t work either.
    Steven Gonzales replied 16 years, 3 months ago 3 Members · 2 Replies
  • Jason Diebler
    June 3, 2010 at 6:13 pm
    Try going into Keyboard Layout > Customize… delete the command, then reassign it. Just a thought, not sure if that’ll work for you.
    Did you see if that command works in other programs like Word, Photoshop? Just to make sure your keys aren’t jammed?
    “The deepest blues are black” – Foo Fighters
    (this doesn’t help me when I’m chroma keying!)
  • Steven Gonzales
    June 3, 2010 at 6:42 pm
    control-v works on the tracks that have auto select enabled. Check your tracks (probably V1, A1, A2) and see that the auto select is enabled. This is the icon on the far right of the grey areas to the left of the tracks.
