Activity › Forums › Adobe After Effects › short cut easy easing
  • short cut easy easing
    Posted by Harry Mao on August 25, 2015 at 8:06 pm
    I’m having trouble creating an easy ease keyframe on my animations. I created few key frames and when I try to press F9 it does’t do anything, I had to manually right click and select key frame assistant and then easy ease. Is there any way to fix this problem? Im using a Mac and AE CC 15
    Daniel Waldron replied 11 years, 1 month ago 3 Members · 2 Replies
  • Nathan Walters
    August 25, 2015 at 8:24 pm
    What kind of keyboard are you using? I had a similar issue years back. Since Macs often use the F1-12 buttons as other functions (adjust screen brightness, volume, etc), sometimes you need to hold down “fn” and then press f9 or whatever f# button you need.
    Nathan Walters
    Halo Union Productions
    https://www.HaloUnion.com
  • Daniel Waldron
    August 25, 2015 at 9:28 pm
    You need change your Mac keyboard preferences to use Standard Function keys. Otherwise, hold down Fn like Nathan said.
