Activity Forums Panasonic Cameras Short 108024p clip taking so long to RENDER in timeline in FCP ?
  • Short 108024p clip taking so long to RENDER in timeline in FCP ?
    Posted by Pierre on July 19, 2006 at 3:03 am
    Basically every single one of the clips that I’ve imported from my P2 card into final cut pro have required rendering. I don’t understand this? I thought one of the main benefits to P2 in unison with FCP was that it wouldn’t require this type of rendering time.
    I’m constantly making sure that the sequence and project match what the footage was aquired in.
    what am I doing wrong? I think I’m missing something.
    Thank you,
    Michael
    David S. replied 20 years, 1 month ago 3 Members · 2 Replies
  • Jeremy Garchow
    July 19, 2006 at 3:35 am
    Your settings are wrong. If you applied a clip to a timeline without any effects/filters and there’s a red render bar, you have a setting wrong somewhere. On the hvx, 1080p is recorded with pulldown in a 60i stream. If you have not removed the pulldown, you need to be in a 1080i DVCPro HD sequence.
    Jeremy
  • David S.
    July 19, 2006 at 2:53 pm
    A render always means the sequence settings do not match the clip attributes.
