Activity › Forums › Avid Media Composer › Shooting with AG-HVX200
  • Shooting with AG-HVX200
    Posted by Jim747 on March 29, 2007 at 9:19 pm
    Can anyone tell me what the process is of shooting HD footage on an AG-HVX200, and taking the files from the p2 cards or firestore storage and getting them into files I can edit with on an avid expressproHD and other Avid systems.
    I know that the HVX200 will capture movie files- does that mean that there has to be some sort of conversion to mxf files to be able to edit in AVID? or does the camera enable you to shoot some other format that AVID can read.
    Jim
    Michael Rothenberg replied 19 years, 5 months ago 4 Members · 3 Replies
  • Joe Womble
    March 29, 2007 at 9:48 pm
    Jim,
    The HVX 200 is my camera of choice; I do 90% of my shooting with it.
    Avid reads MXF files natively and does not require any rendering or conversion. If you have an Avid system older than x.7, just copy the audio and video .mxf files to the Avid MediaFiles folder on your data drive. Then open Avid, watch as it rebuilds the database for these drives, and then open Media Tool. Drag the files into a folder in your project and start editing.
    If you have version x.7, it gets easier and better! Read this:
    https://www.avid.com/content/10541/README_XpressPro.pdf
    Regards,
    Joe Womble
  • Eivind
    April 2, 2007 at 7:41 pm
    But can you do the same process in a pal-project (720p/25)??
  • Michael Rothenberg
    April 6, 2007 at 2:41 pm
    Hi Joe
    I’m on AXP 5.7 and have had good luck with the workflow you describe for the P2 footage I shot at 24PN. Next I transcoded my Varicam and P2 footage to SD 23.976 for offline and it’s working well. But I am having a separate problem.
    I shot some footage time-lapse using the “interval” option on the HVX200. But that required me to change over to “video” and a 60P frame rate during shooting. Now I can’t seem to transcode that footage over to SD 23.976 although I can see it in a 720P 60 project. I can choose transcode from the SD project but nothing happens.
    Any ideas or workarounds?
    Michael
    Michael Rothenberg
    Peak Productions
