Activity Forums Canon Cameras Shooting in HD on Canon XHA1 w/ Focus Firestore FS-100 Hard Drive
  • Shooting in HD on Canon XHA1 w/ Focus Firestore FS-100 Hard Drive
    Posted by Jon Metallo on June 8, 2019 at 2:21 pm
    I recently got a couple of hard drives to extend the life of my Canon XHA1. I just got a Focus Firestore FS-100 Hard Drive (along with my previous post question about my FS-5). Whenever I try to record in standard definition (DV) the hard drive records perfectly, however whenever I try to record in HDV mode I cannot get the hard drive to work.
    How can I make this hard drive record in HD?
    Thanks 🙂
    Francois Pénzes replied 7 years, 1 month ago 2 Members · 1 Reply
  • Francois Pénzes
    July 16, 2019 at 4:16 pm
    Hi Jon
    What kind of drive is it ? SSD or Disk ? Is it formatted in NTFS, FAT32, etc…? Sometimes if they are not formatted FAT32 it could create problems. Try it out and let me know. The draw back with FAT32 is that you are limited in the size of the file. When you try to put them together you get a couple of dropped frames and some audio loss. Mind you some capture software will make them seamless when you use them to transfer your files from your capture unit to your PC
    Cheers !
    PC Win 10 Pro 64-bit 16gb Intel® Core™i7-2600k Quad Core 3.40GHz
    Cameras: Canon XF305 + Canon XH-A1
    Blackmagic HyperDeck Studio Mini
    Vegas Pro 16, User since Vegas 3.0
    \’\’When the cutting stops, the editing begins…\’\’
