Activity Forums Apple Final Cut Pro Legacy Shooting 16:9 on Canon xl2 but need 4:3 version as well
  • Shooting 16:9 on Canon xl2 but need 4:3 version as well
    Posted by Rsk3527 on August 13, 2005 at 6:45 pm
    I am going to be shooting a show 16:9 on the Canon XL2 but also need a 4:3 version. I was wondering if there was an easy way to render out a 4:3 dv version out of Final Cut Pro 5. Also what is the proper codec to bring in the 16:9 version and what size in pixels is the footage? It will be squeezed if you bring it in using the regular dv codec, right? Help here would be greatly appreciated.
    Thank You,
    Rich
    Rsk3527 replied 21 years ago 2 Members · 7 Replies
  • 7 Replies
  • Chris Poisson
    August 13, 2005 at 7:14 pm
    Hey Rich,
    You can shoot it wide enough so that you can crop it in a 4×3 sequence, or you could letterbox it. Unless you have a bunch of graphics that you want to preserve the quality on, just do it all DV. The size for graphics if you do DV is 864×480.
  • Rsk3527
    August 13, 2005 at 11:33 pm
    What is the process of cropping it in the 4:3 sequence. Is there a way to control the 4×3 crop or do you just drop the 16:9 footage into a 4:3 sequence and final cut will automatically crop it.
    -Rich
  • Chris Poisson
    August 14, 2005 at 1:09 pm
    Rich,
    I don’t have FCP opwn right at the moment but as I recall you just put the footage in a 4×3 sequence and open the clip in the viewer, and go into the motion tab under distort, and I think you just distort it 33%. Anyways you will see when the proportion is right in the canvas.
  • Chris Poisson
    August 14, 2005 at 1:13 pm
  • Rsk3527
    August 15, 2005 at 3:33 pm
    Chris,
    Thanks for your help so far, but I don’t think I was clear. I am shooting two different framings for two different deliveries. I want to end up with a traditional 4:3 square and a 16:9 version. So I want to know how to center extract the 4:3 square from the sqeezed 16:9 into a ntsc sequence. Not just create a 4:3 letterboxed version. I want to fill a 4:3 square with the center extracted image.
    Rich
  • Chris Poisson
    August 15, 2005 at 3:54 pm
    Rich,
    I understand what you want, just put the anamorphic footage into a 4×3 sequence, open the clip in the viewer, go the the motion tab and twirl down distort, and type -33 in the aspect ratio box. Done.
    You will see the edges of the clip in image and wireframe spread out and crop the sides.
    But as I said in my first post, you will have to shoot wide enough to be able to lose the sides.
  • Rsk3527
    August 15, 2005 at 4:06 pm
    Chris,
    Thanks a lot.
    -Rich
