Shooting 1080i with DVCProHD and AVCIntra – how to mix clips on a timeline?
We shoot 1080i, with a Panasonic HPX500 (DVCProHD) and with a small Panasonic (I don’t have the model). The smaller Panasonic records AVCIntra – ending up with .MTS-files on a SD card. After a few disappointing reads on the internet, I found out that I can actually use Log & Transfer in FCP7 to ingest the clips from the SD card. (I have no audio when scrubbing the clips in L&T, I guess this is how it is?)
If I bring a transferred clip to the timeline, FCP sets it to ProRes422, HDTV (16:9) and with upper field dominance.
If I remember correctly, DVCPRoHD uses lower field dominance.
This is a 2-camera shooting, so there’ll be A/B-roll. THe main camera (also picking up audio) will be the HPX500.
How do I set up FCP and/or the logging, so that I get the best result from these two cameras?
Or should I use other software to convert the .mts files to DVCProHD, before importing the files in FCP7?
