Activity Forums Adobe Premiere Pro Shooting 1080 24p for 1080 60i drop frame conversion
  • Shooting 1080 24p for 1080 60i drop frame conversion
    Posted by Christian Stoehr on March 11, 2013 at 7:41 pm
    Got a quick question that might be a old rehash. We have do deliver a project or broadcast at 1080 60i Drop Frame, and are shooting on Scarlet. The workflow that the team is using right now is to shoot at 1080 16:9 24p. They then do the whole post in 24fps once its finished they exprt, and then reimport and put it on a 60i timeline. It then has a few extra frames on the timeline, since the frame rate change, that they just cut off.
    I know this can`t be the right workflow, and was wondering what the best way is to convert the final to 60i, or if we should consider shooting it that way, which they insist on the 24p look.
    Chris
    Eric Hansen replied 13 years, 6 months ago 2 Members · 2 Replies
  • Christian Stoehr
    March 11, 2013 at 9:00 pm
    Here is what I found in the forum from Dave LaRonde:
    Make sure the footage is interpreted as 23.976, and NOT 23.98
    Put the footage into a 1920×1080 comp at 59.94 frames/sec, which automatically spreads the film frate across the video frame rate
    Nest the comp in another 1920×1080 comp at 29.97 frames/sec, which gets you to the proper frame rate
    Render the 29.97 comp as interlaced, UPPER FIELD FIRST, which gives you the fields you want
    The result: a 108060i file, which is the same thing as a 1080 29.97 file with interlacing.
  • Eric Hansen
    March 11, 2013 at 10:25 pm
    I use Apple Compressor to add a pulldown to 24p footage. not sure if it would be faster than AE or not.
    Eric Hansen
    Production Workflow Designer / Consultant / Colorist / DIT
    https://www.erichansen.tv
