Activity Forums VEGAS Pro shoot HDV, downconvert, edit, replace with HDV in Sony Vegas 8
  • shoot HDV, downconvert, edit, replace with HDV in Sony Vegas 8
    Posted by James Hughes on April 19, 2009 at 9:18 pm
    Hello,
    I have a V1E and want to shoot a project in HDV, the only problem is my computer isn’t fast enough to edit HDV footage.
    If it is possible, I want to shoot in HDV, downconvert to SD, edit in SD, then when the project is finished, replace the footage with the HDV footage and render the final project in a HD format (mpeg2?)
    I am using Sony Vegas 8.
    Any help would be great!!!
    All the best,
    James.
    Khanh Nguyen replied 17 years, 5 months ago 2 Members · 1 Reply
  • Khanh Nguyen
    April 20, 2009 at 3:54 am
    What you are asking is called “proxy editing”. There are a couple of ways to do just that. Look here:
    https://eugenia.gnomefiles.org/2007/12/12/proxy-editing-with-sony-vegas/
    especially the “update” part.
    Even with proxy editing, you still need a relatively good computer since the frame rate will drop significantly with effects turned on.
    Another method is using an intermediate codec (such as cineform). Vegas 8 shipped with cineform 2.8 (which has a limit of 720p resolution which is not too bad). The cineform files should playback much better than our original files (and much bigger too).
