Activity Forums Adobe After Effects Shine and CS3 render issue
  • Shine and CS3 render issue
    Posted by Satesh Ramjattan on August 12, 2007 at 10:10 pm
    Hello,
    I just got the new shine from trapcode/Rdgiant for AE CS3. whenever I apply shine to anything, it looks fine, but when I render out with lower fields (QT motionjpeg and Animation) everything looks dulled and seems like an interlace thing. I say this because I did a test on just plain text and rendered out one with lower fields on and one with it off. The one with it off looks good, but I need to render out with lower fields. anyone experience this or have a suggestion?
    thanks
    Steve Duddleston replied 19 years ago 3 Members · 9 Replies
  • 9 Replies
  • John Dickinson
    August 12, 2007 at 10:43 pm
    Can you show us an example frame?
    JD
    John Dickinson
    Motionworks
    http://www.motionworks.com.au
  • Satesh Ramjattan
    August 12, 2007 at 11:31 pm
    How do I post a frame or clip in this forum?
  • John Dickinson
    August 12, 2007 at 11:53 pm
    Can you upload to a server and provide the link? If not try emailing them to me.
    JD
    John Dickinson
    Motionworks
  • Satesh Ramjattan
    August 13, 2007 at 12:17 am
    hi john.
    i sent to ur .mac email.
    really appreciate it.
  • John Dickinson
    August 13, 2007 at 12:34 am
    When you render to fields are you reimporting it into AE to look at it? AE will be separating the fields on import, which will give you a resolution-hit. You may also like to send me the work file so I can take a look.
    JD
    John Dickinson
    Motionworks
  • Satesh Ramjattan
    August 13, 2007 at 1:11 am
    No I am looking at it on the QT movie and a broadcast monitor. The file i have was just to test the plugin. all i really did was create text in AE CS3 on a mac pro(new intel quadcore) and popped shine on and animated the source location property from left to right and rendered out as I usually do. Could you just test on your machine and render out with lower fields? Now, it will look normal if you do a RAM preview, but once you render out with fields is the problem. Once again I really appreciate your help.
  • John Dickinson
    August 13, 2007 at 1:37 am
    Yep, same problem here, it looks like a bug. I’ll report it.
    JD
    John Dickinson
    Motionworks
  • Satesh Ramjattan
    August 13, 2007 at 1:45 am
    Many thanks John. Not happy about the bug, but glad it’s not just me. Wonder which side the problem is from, AE or Trapcode/RedGiant.
  • Steve Duddleston
    August 14, 2007 at 11:34 am
    I had same issue, but worked around by saving RAM preview, then used normal Render settings for interlaced output.
