Activity Forums Adobe After Effects Expressions shifting the point of interest
  • shifting the point of interest
    Posted by Mark Doctor on August 27, 2018 at 9:01 pm
    I’ve placed a 3D-cube in front of AE’s camera and it lines up with the 2D-background by using the 3D-camera-tracking. Now I want to zoom in on the cube
    By turning the background into a 3D-layer and parent it to the camera-position, I’ve succeeded to pan and tilt the camera and zoom towards the cube. But…
    Once zoomed-out, I need to set the point of interest towards the (constant moving) background. And zoomed-in I need to set the point of interest towards the 3D-cube.
    So i was thinking of an expression which gradual transforms between both positions. Like a position-A to -B transformation with a percentage slider that can be key-framed.
    But I guess it has been done before and i’m not that great at expressions. Also I maybe overlooked some simpeler solution.
    Thanks for any input, Mark
    Mark Doctor replied 8 years ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    August 29, 2018 at 12:22 pm
    How about using a position-keyframed 3D null object for the point of interest, pick-whipping the camera POI to it?
    Senior Graphic Designer
  • Mark Doctor
    August 29, 2018 at 7:11 pm
    Solved! Key-framing a null wasn’t an option; The null would need a key-frame at every frame just like the camera, to keep up with the background parented to the camera.
    //3D point expression:
    A = thisComp.layer("BackGround");
    AW= A.toWorld(A.anchorPoint);
    //vector expression:
    A = effect("Point A")("3D Point");
    B = effect("Point B")("3D Point");
    //vector to B
    C = B - A;
    // 1% vector
    D = effect("Slider Control")("Slider")*C/100;
    // point A & vector added
    E = A + D;
