Activity Forums Apple Final Cut Pro Legacy Shifting Audio By The Field (Not The Frame)
  • Shifting Audio By The Field (Not The Frame)
    Posted by Brian Douglass on January 15, 2009 at 4:54 pm
    I’m working on a spot that the audio would be perfect, not on the frame, but just in between.
    Since audio isn’t bound to a frame rate, is it possible in FCP to slide the audio by the field?
    In FCP when you move your mouse through your sequence, there’s a thin bar on the top that moves along, and also (when your zoomed in) moves inbetween the frames.
    Is this even possible?
    Brian Douglass replied 17 years, 7 months ago 2 Members · 2 Replies
