Activity › Forums › Adobe Audition › shifting a clip frame by frame for lip-syncing with Audition
  • shifting a clip frame by frame for lip-syncing with Audition
    Posted by Fabrizio Carraro on October 1, 2009 at 2:23 pm
    Is there any handy way to shift a clip right or left, frame by frame? I would like something similar to proTools, where you set the shift amount (1 frame, 1/2 a frame…) select the “region” and just press the plus or minor sign. This is very handy when you want to lip-sinc audio vith video. I couldn’t find any way with Audition 3. There must be a way!
    Thanks a lot!
    Fabrizio
    Murray Nelson replied 16 years, 8 months ago 2 Members · 1 Reply
  • Murray Nelson
    January 9, 2010 at 4:44 pm
    whats the sampling rate?
    if 44.1 then divide by your frame rate to give you samples per frame then changing select to ‘samples’ then just add or subtract to move sound track.
