Activity Forums Apple Final Cut Pro Legacy shift in brightness in the canevas when press play
  • shift in brightness in the canevas when press play
    Posted by Guillaume Chadaillac on March 26, 2011 at 7:08 pm
    Hi guy!
    I am running into something that has never happened to me before…
    I am color correcting some shots.
    I do my things… color correct them… I m happey with it.
    And when I press play… the brightness in the canevas increases by … a lot
    On my other projects, there is no shift in brightness between the play / stop state.
    I tried to tweak the sequence settings… but everything seems to be in order. (rendering the YUV space at highest quality, rendering coded same as sequence, using apple prores LT, luma warning turned off)
    any ideas?
    Guillaume Chadaillac replied 15 years, 6 months ago 3 Members · 4 Replies
  • Steve Eisen
    March 26, 2011 at 9:51 pm
    You can’t judge quality from your computer monitor.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Guillaume Chadaillac
    March 26, 2011 at 10:34 pm
    I am not judging quality.
    I have 6 final cut sequences.
    ALL of them shot with a canon 7D under the same light conditions.
    ONE and only one of these sequences increases drastically in brightness when I hit play and returns back to normal when I hit pause.
    The other sequences behave nicely.
    I say this is a settings problem that i messed up and that i am enable to fix. Not a quality problem….
  • David Roth weiss
    March 26, 2011 at 10:43 pm
    That one sequence most likely does not have settings that match your video. Do a copy all from that sequence and paste into a duplicate of one of your other sequences after deleting all of it’s clips.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
    March 26, 2011 at 10:50 pm
    Thanks for your response.
    I did create a new sequence. I dragged some of my files in it so that FCP asks me if I want my sequence settings to match my clips. I said yes.
    but the problem persists.
    And that s not even something exotic!
    Apples prores LT 1920*1080 de-interlaced…
