Activity Forums Adobe Premiere Pro Shift F in FCP 7, what’s it in PP CC 2014?
  • Shift F in FCP 7, what’s it in PP CC 2014?
    Posted by Kent Beeson on July 13, 2014 at 4:05 am
    latest PP CC2014 – how to create a custom key stroke to find bin, i.e., after match frame then it shows up in source monitor, how to then do what FCP 7 had which was shift F, so what’s the equivalent in PP CC 2014
    thanks
    Kent Beeson replied 12 years, 1 month ago 3 Members · 4 Replies
  • Dennis Radeke
    July 13, 2014 at 11:32 am
    There is a search field in the project panel directly for you to type in and in any separate bins that you open up.
    Also, if you go into Keyboard shortcuts, go to Panels>Project Panel>Project Panel Menu and you will find the ‘find…’ command. Assign it to whatever keyboard shortcut you’re comfortable with.
    HTH,
    Dennis – Adobe guy
  • Kent Beeson
    July 13, 2014 at 6:30 pm
    Thanks for reply – but I found it’s actually in Source Monitor Panel/Reveal in Project, then I assigned it the shift F key and it works like FCP 7’s Shift F “find bin”…thanks
  • Kevin Monahan
    July 15, 2014 at 7:56 pm
    Hi Kent,
    Yes, you found it. “Reveal Master Clip” is the command in FCP that is called “Reveal in Project” in Premiere Pro. What you might want to do is set the same keyboard shortcut for “Reveal in Project” in Keyboard Shortcuts for the Timeline pane as well. You can set the same shortcut for multiple panes now.
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
  • Kent Beeson
    July 15, 2014 at 8:41 pm
    Good idea, I’ll do that, thanks
