Activity Forums Adobe After Effects shatter map effect bad edges
  • shatter map effect bad edges
    Posted by Curt Saeui on February 6, 2008 at 12:15 am
    I’ve been using the shatter effect and have it animating and breaking apart using a custom map. I have it animating the way I want, but the edges of the pieces are kind of muddy. I tried using the custom map as a vector pattern as well as a Tiff… no success
    Heres an image of the map and the shattered piece…
    https://img.photobucket.com/albums/v141/rideshare/shatter_exp.jpg
    the shapes i want shattered are not overlapping or touching in the b/w map…
    is there a setting im just not seeing???!
    David Bogie replied 18 years, 7 months ago 3 Members · 2 Replies
  • Steve Roberts
    February 6, 2008 at 3:43 pm
    Hm. I don’t Shatter much, but Googling “shatter map” and “clean” led to this link, among others:
    https://forums.digitalmedianet.com/cgi-bin/displaywwugpost.fcgi?forum=adobe_after-effects&post=000217164739.htm
  • David Bogie
    February 6, 2008 at 8:35 pm
    Creating a custom shatter map is really difficult and the information on how to do it isn’t as readily available as it once was. It depends on more than hard edges and if any pixel is seen by Shatter as crossing a line, the edge will be muddy, as you say. It is largely a color threshold process, not a vector process. You might check Total Training’s site to see if Brian Maffit, the guy who invented Shatter, still has anything up that might help. Hmm, just dropped by, doesn’t look like they have anything online that’s free.
    bogiesan
