Activity › Forums › Adobe After Effects › Shatter Effect: undesired transparant sides
  • Shatter Effect: undesired transparant sides
    Posted by Geoff Vane on August 29, 2012 at 1:36 pm
    When I type some text, and make it explode with shatter, the extruded pieces have a transparent side where you can peek into the piece. This is due to the transparency surrounding the text.
    Is there a way to have solid shattered pieces with transparent areas around it, but where the sides are solid?
    I can use the text itself as a pattern, but that gives text shaped pieces that do not explode into shattered pieces.
    Vishesh Arora replied 14 years, 1 month ago 3 Members · 2 Replies
